Results 1 to 2 of 2
Thread: Upgrading when Premium Registered
  1. #1
    Join Date
    Dec 2017
    I see v7.0 is now available. I am running v6.1 (on Windows 10). If I upgrade to v7.0 in situ will it still know I have the Premium functionality - specifically I always use Folder & Filename browsing & can't afford to lose that. Also, is there any automatic upgrade function? I can't see anywhere it checks versions, or anywhere I can enable/disable automatic upgrade. Does it rely on me checking your website from time to time to see if there's a new version?
  2. #2
    Join Date
    Apr 2002
    Re: Upgrading when Premium Registered
    You can download the registered version here:
    http://www.dbpoweramp.com/registration/
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
