NOTE: Any posts to this forum on or after 16th April will disappear in few days when we transition to a new forum
Results 1 to 3 of 3
Thread: please help, got big problem with editing the browse tree
  1. #1
    Join Date
    Nov 2020
    hi
    Since 3 days I’m testing Asset R 7.0 trial on a mac mini server i7-2012 OSX Mojave and got Linn Kazoo for mac/iPhone/iPad…
    ...first to say asset is great app, fast and not as buggy as twonky.
    before I buy the registration to premium I’m testing options, but without sucess:
    everything I do = editing in preference window „ Browse Tree“ to get a view Browsing by Folder&Filename is without any effect:
    I edited it as to be shown in first line below artist, album, title and above composer and saved = no effect at control points
    I deleted everything else without Browsing Folder&Filname in „Additional“ and saved = no effect at control points
    I don’t want to have too much options in Kazoo control point, since 10years I was using Twonky (from version 4 to 8.5) with Foldernavigation on 5 different Servers. Twonky had a lot of bugs but I was always able to find a workaround.
    keep it simple as could be, best thing to me is to get „Browsing Folder&Filname on top, but can’t find the fix to do that
    greetings
    W. Lui
  2. #2
    Join Date
    Nov 2020
    Re: please help, got big problem with editing the browse tree
    hi
    found out one great thing: once Folders&Filename is selected at Kazoo contol points it is saved means if I switch to the Linn TuneIn option and want to go back to my music in asset it shows Folders&Filename selected directly. I don't have to select to the whole menue, thats really great. I mean in twonky I had to select through whole menue to get back to my albums and folder structure. So Asset is truely very nice and it hast not the "alphabet bug" (tracks not shown by tracknumber but wrong in alphabetical order)which is not corrected in twonky since several versions. I had to made the correction by myself with editing the .xml view file...
    greetings
    W.Lui
  3. #3
    Join Date
    Nov 2020
    hi
    found the answer/reason here in forum. Version R7.1 will support editing browse tree in mac UI...
    https://forum.dbpoweramp.com/showthr...-Mac-amp-Linux
    but I had to buy Asset premium first an then upgrade to 7.1 to get correct browse tree editing function in mac os asset UI...
    what I like, by searching in this forum I can help myself to find solution...using new app like asset means new learning
    greetings
    W.Lui
Posting Permissions
  • You may not post replies
  • You may not edit your posts
