24bit
My player hi end Pioneer N70a crach when starting to play music 24 bit with Asset UPNP. But not all files 24 bit. When I use other DLNA server it works without any problem (Synology NAS DLNA server, PLEX DLNA). The same problem with minimserver DLNA.
Re: 24bit
Set asset to transcode flac (I assume you are using this) 'to Wav' then the player does not have to decode anything.
Re: 24bit
Yes, but now transcode all flac to wav, but i want only transcoding to wav, when is not possible play flac.
Re: 24bit
That is not possible, sorry.
Re: 24bit
Here is a link to the What HiFi review of the Pioneer N70a streamer
https://www.whathifi.com/pioneer/n-70a/review
This review is a bit confusing but seems to suggest that WAV and FLAC files can only be played via the units USB imput and that the ethernet imput requires LPCM format files in which case perhaps natmar could have Asset transcode his files to LPCM assuming these are being streamed over his ethernet network.
I must admit it seems an odd way for Onkyo/Pioneer to configure their network streamer but it might explain natmars issue.
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
