R17.2 - thumbnail handler not working
  • fyl
    • Oct 2020
    Re: R17.2 - thumbnail handler not working
    Originally posted by Anakunda
    The dbPA property handler however works as expected and shows embedded artwork if included, so the issue concerns only the thumbnail provider.
    I've also upgraded JRiver MC from 26.x to 27.0.20 and pane thumbnails don't display properly (files and "currently playing" thumbs are unaffected). Could be a conflict between handlers supplied by dBpoweramp and JRiver.
    • Anakunda
      • Oct 2010
      • 12
      I can't confirm it, I haven't JRiver installed, but have installed more thumbnail handlers, guessingly for different file types.
        • 43918
        Can people say which was the last version of dbpoweramp where the thumbnail worked for them please.
        • Anakunda
          • Oct 2010
          • 12
          R17.1
          • fyl
            • Oct 2020
            Originally posted by fyl
            Same problem here : the thumbnails have disappeared after upgrading from 16.x to 17.2 (both reference registered).
            Running Windows 10 Pro 19041.508 64-bits, French version, clean reinstalls of Windows as well as dBpoweramp 64-bits, no security add-ons (standard Windows fare, Defender et al.), default dBpoweramp config (same when playing with the params)
            Just upgraded W10 from 2009 to 20H2 and the miniatures are back...
            • fyl
              • Oct 2020
              16.6
              I usually wait a few months before upgrading stable software to a major release.
                • 43918
                #22
                You said they are back working again with R17.2? on the last Windows update?
                • fyl
                  • Oct 2020
                  Yes, perfectly. I guess that the installations (R17.2 and/or MC 27) messed with miniature handlers and that the update to W10 20H2 reinstalled proper ones.
                    • 43918
                    #24
                    Please see the last message here:
                    This new release features many enhancements, it is 20% faster on multi-core machines and is future-proofed through handling 64 cores. A new DSD encoder is included as standard (Reference), as well as many previously optional codecs, which are all updated to the latest releases. A new Quick Convert right explorer right click
