Converting Hi-Rez to CD quality
  • JukKluk
    • Sep 2012
    I have been told that it's possible to create lower rez files from higher ones. Essentially, I just want to make the lower rez (CD quality) copies so that they can be played from the USB input in my car music player.
    Can dbPoweramp do this? If so, how. The less technical the answer the better, my eyes and mind glaze over with too much technical talk.
    Cheers,
    JukKluk
    • 43898
    Re: Converting Hi-Rez to CD quality
    Yes, include the DSP Effects:
    Resample (set to 44KHz)
    Bit depth (set to 16 bit)
    Also take a look at this program:
    dBpoweramp Image Converter - PNG, Portable Network Graphics, Bitmap, GIF, JPEG, JPG, TIFF, Webp. Free Download (21 day full trial), start converting today
    Which is geared to creating collections for the car.
