1 specific audio CD not detected
I'm running dBpoweramp (17.1) on a macbook Pro (Catalina 10.15.6), with an external LG drive (M-Disc) which always performed flawless.
Today however, I ran into a problem with 1 specific audio CD that isn't detected by dBpoweramp, the front LED of the drive blinks and I hear it spinning from time to time, but the application screen shows no progress as usual.
Any ideas what to try?
Re: 1 specific audio CD not detected
It is likely the cd drive its self cannot read the disc, try iTunes and see if that can see the disc.
iTunes doesn't see it either.
Unfortunately I don't have another drive
I had one CD like that and all I did was clean it. It looked clean before I wiped it.
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
