Attached is a screen shot of a CD rip, i assume when AR fails, but a check mark on Secure, the rip is good?
Normally rip with green checkmark is good rip (secure) when one doesn't get an AR match. But this is a bit of an odd case, as you are getting AR matches for all the other tracks on this album, but not for this track. So something is odd here. I'd try ripping that track with a different drive for example.
Ok, that brings up a question i have always wondered about - since this is a bit by bit reproduction, i assume it doesn't matter what drive or computer music is ripped on (as long as I get the AR checkmark)? Over time i ripped every CD I had on an old Mac Pro, but did it in Apple Lossless (thru iTunes), i am now going back and using DBpoweramp to get the verified Accurate rip in FLAC.
Thanks, great idea!
Thanks for all the help. There were a few tracks that didn&*8217;t match accurate rip, but most CDs were all good! I was liking cleaning up the tags, but I can do that with PertectTunes also!
