Convertting DSF to Flac - Searching for best SETTINGS dBpoweramp-Codec-DSD-SACD v.3
win 7 64x
Thank you for your help sir
I have a dsf file and would like to convert it to Flac using the best possible settings.
As you can see from my snapshot my original DSF file has a sample rate of 176.4 Khz.
Question 1.Would it be counter productive to use a higher sample rate PCM 192 KhZ ?
Question 2.Is a DOP converted file superior to PCM conversion ?
Re: Convertting DSF to Flac - Searching for best SETTINGS dBpoweramp-Codec-DSD-SACD v
VERY VERY SORRY PLEASE DISREGUARD THIS THREAD.
i WILL FORMULATE A MORE IN DEPTH THREAD.
thank you so much support
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
