Results 1 to 9 of 9
Thread: CD Unloading Delay (Nimbie)
  1. #1
    Join Date
    Jun 2020
    Just got myself a Nimbie and I am working through digitizing my library.
    Everything working great but something I am curious about. The "Unloading CD" and "Loading CD" steps of the batch ripping are taking very long. Way longer than the time to rip a CD. Is this normal? Here is what I have for my Batch Ripper settings:
    Any suggestions?
    Thanks!
  2. #2
    Join Date
    Apr 2002
    Re: CD Unloading Delay (Nimbie)
    How long to load and unload a CD?
    On the 2nd image, click 'test' to load and unload manually.
  3. #3
    Join Date
    Jun 2020
    Minutes. Is this normal?
    Are you recommending I do this during the batch ripping process? Would that go against the whole automated aspect of using the Nimbie?
  4. #4
    Join Date
    Apr 2002
    Not during the batch rip, just to see how long it takes to complete the test load.
  5. #5
    Join Date
    Jun 2020
    Six minutes to load and the same to unload.
  6. #6
    Join Date
    Jun 2020
    Here's an example... This CD single is still "processing" after 21 minutes.
  7. #7
    Join Date
    Apr 2002
    You would have to try Nimbies own software as a test to see how quick it is.
  8. #8
    Hello: I was looking at Nimbie. I would love to know how that is working out. Are you planning on selling the unit after you are done ripping?
  9. #9
    Join Date
    Dec 2018
    Location
    Germany
    Do you use Windows 10?
    Then we may have a similar problem.
    It usually takes about 1 second to load and unload a CD.
    But for a few weeks now, we have had the problem that after a few CDs, suddenly a CD can no longer be loaded - or ejected.
    It takes hours to load ......
    If you then switch off the nimbie and the software restarts, it works for the next 25 CDs. By the way, the mechanical ejection at the button of the nimbie is also blocked.
    We are very "very" sure that this problem is caused by a Windows update that we installed around April 2020.
    As soon as we do an rollback to an older version of Windows 10, the problem is gone.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
