Results 1 to 2 of 2
Thread: Problems opening Asset
  1. #1
    Join Date
    May 2020
    Hello
    I have just purchased Asset UPnP but am having problems opening it on my PC (runnning Windows 10). Having just installed it I get the following screen
    But when I click on OK, the box just disappears and nothing else happens. I can't seem to open the program at all.
    thanks
  2. #2
    Join Date
    Apr 2002
    Re: Problems opening Asset
    That is Asset it is not a player, it is an UPnP server which runs in the background.
    If you have a UPnP audio device it will be able to see Asset on your network and play music from it. Asset has automatically scanned your music folder.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
