Asset 6.6 RPi 4: not in gzip format
  • Bubblefish
    • Apr 2020
    after downloading the premium asset file ver. 6.6 the tar process exits with the message "... not in gzip format ..". Decompressing on Windows was possible.
    Thanks for support - Martin
    Super Moderator
    • 1365
    Re: Asset 6.6 RPi 4: not in gzip format
    Have you tried downloading the Asset tar.gz file to your Raspberry Pi again?
    Can you please post the full command line used to extract the Asset archive as well as the full output?
    • Bubblefish
      • Apr 2020
      Here's the input/output:
      input:
      wget http://secure.dbpoweramp.com/downloa...num=xxxxxxxxxx -O asset.tar.gz -> then connection established, file downloaded, then
      tar -zxvf *.gz
      output:
      gzip: stdin: not in gzip format
      tar: Child returned status 1
      tar: Error is not recoverable: exiting now
      • Bubblefish
        • Apr 2020
        -> wget http://secure.dbpoweramp.com/downloa...num=1234567890 -O asset.tar.gz
        <- file downloading
        -> tar -zxvf *.gz
        <- gzip: stdin: not in gzip format
          Super Moderator
          • 1365
          Thanks for the details.
          It would appear that the download step is failing for some reason.
          I assume that you're trying to download with valid order number in your download link.
          What if you try downloading over https rather than http:
          Code:
          wget [b]https[/b]://secure.dbpoweramp.com/downloadorder.aspx?ordernum=123456789 -O asset.tar.gz
          .. then resume original instructions?
          If this doesn't help, please try transferring Asset package file from your computer (one that's verified to extract correctly) to your Raspberry Pi, then extracting it.
          • Bubblefish
            • Apr 2020
            Thanks for help - but nothing changes.
            https brings the same situation -> not in gzip format
            Loading via Windows brings not the same file permissions after decompressing, but it's possible. The comparison with an old version 6.4 offers differences.
            Is this file really in gzip format for Linux?
              • 43901
              Try downloading the file on the PC, then transfer to the NAS and try to unzip
              • Bubblefish
                • Apr 2020
                Ok, done: before unzipping I changed the owner/group and AssetUPnP started correctly
