Apply De-emphasis to CD tracks marked with Pre-Emphasis
    • 43921
    Re: Apply De-emphasis to CD tracks marked with Pre-Emphasis
    Both the engaged and not are the same file, so no de-emphasis is running. What security software do you have which might be blocking the action?
    • c-eling
      • Apr 2014
      • 21
      Correct. Not engaging Spoon.
      Windows Security, Win 10 PC
        • 43921
        Which version of dBpoweramp do you have? Reference?
        • c-eling
          • Apr 2014
          • 21
          17 Reference, yes. Updated a week or so ago. I'll try a complete un/re-install
          • Hiroshi
            • May 2020
            Certain CDs have been created with pre-emphasis, it is down to the cd player to apply de-emphasis on playback, dBpoweramp will now do this when ripping.
            Hi Spoon
            Thanks for the good news. I have been waiting long for this de-emphasis function working directly with flac.
            1) Can you share the screen of cd ripper and show how this ripping works when using cd ripper?
            2) Can I apply de-emphasis to the flac files, which I ripped using cd ripper R16 and before?
              • 43921
              #21
              1) It is fully automatic
              2) Include the DSP de-emphasis and convert flac to flac.
              • Hiroshi
                • May 2020
                Thanks Spoon
                2) To decode flac file previously ripped from pre-emphasis CD, do I simply decode it selecting the file using batch music converter?
                Does it detect pre-emphasis file from tag data or not (sometimes, there is a miss-detection in CD ripper track technical, so how to avoid miss conversion from normal file)?
                  • 43921
                  #23
                  You convert FLAC to FLAC with the dsp effect de-emphasis. Note if you include that effect then the process is always done, as there are no flags in files. You should only do this once.
                  • Hiroshi
                    • May 2020
                    I see. I haven't downloaded R17 yet, but do I add DSP effect to Batch Music Converter and press "convert"?
                    Then delete DSP effect after using it, since it does not detect pre-emphasis tag flag. Correct?
                      • 43921
                      #25
                      Correct
                      • Hiroshi
                        • May 2020
                        Thanks Spoon
                        I will try it!
                        • c-eling
                          • Apr 2014
                          • 21
                          #27
                          Thanks for fixing this issue Spoon, works like a charm
                          • Oggy
                            • 697
                            #28
                            Just found a couple of old CDs with pre-emphasis that I'd originally ripped with iTunes. Extremely easy to use and very happy to replace them with de-emphasis applied and AccurateRips.
