Results 1 to 3 of 3
Thread: Track Titles and UI issues.
  1. #1
    Join Date
    Jul 2010
    Still not transferring titles and same user interface issues.
    https://ibb.co/B3TPV2f
    https://ibb.co/6wmhhHL
    https://ibb.co/5x04WH1
    https://ibb.co/5YpCrt9
    On the UI issues, 1920 x 1080 with the default setting "make everything bigger" 100% (recommended).
    On the track titles, this CD isn't my library.
  2. #2
    Join Date
    Apr 2002
    Re: Track Titles and UI issues.
    Uncheck all providers, except the top 6 on the list (down to and including freedb).
    The scaling this is an accessibility option you have set, which is just setting the text size bigger and not the rest, it is best to set that option to off then right click on desktop >> display settings
    change the DPI scaling slider there to 150% or 200%, restart windows between changing the setting.
  3. #3
    Join Date
    Jul 2010
    That took care of the track titles.
    Changing DPI scaling slide does the same thing.
    It almost seems like font issues but I'm using the default MS font.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
