NOTE: Any posts to this forum on or after 16th April will disappear in few days when we transition to a new forum
Results 1 to 11 of 11
Thread: Meta data only retrieved from GD3 no ablum art
  1. #1
    I'm having a problem with the meta data with R16.6 in Windows 10
    When I retrieve meta data only data from GD3 makes it through. I've tested individually with a CD that I know worked in the past and only GD3 works. I also don't get any album art.
    I've uninstalled and reinstalled and it still isn't working.
    I'm using windows defender firewall but I can't see the an app that I should let through.
    Any ideas of what else I can try?
  2. #2
    Join Date
    Apr 2002
    Re: Meta data only retrieved from GD3 no ablum art
    Try a different CD to be sure.
  3. #3
    Thanks for the reply
    I already tried with a couple of CDs that worked before. I have the same issue.
  4. #4
    Join Date
    Apr 2002
    If you look at dbpoweramp control centre it says Reference registered?
  5. #5
    Fully registered, no restrictions
    In advanced settings access to the internet is checked.
  6. #6
    Join Date
    Apr 2002
    Try starting your Windows in Safe Mode (with Networking), right click on CD Ripper (or dBpoweramp Control Centre) >> run as Administrator
  7. #7
    Join Date
    Mar 2020
    I am having a similar problem. No artwork appearing. It always did and now it is blank and says no artwork found. I have tried CDs that worked in the past and now they don't.
    I even purchased the latest version today and that does exactly the same. There must be something wrong at DBs end!
  8. #8
    Join Date
    Apr 2002
    If you insert a popular CD then click on refresh (two blue arrows on tool bar), then click the review metadata icon (red icon) all 4 providers are filled?
  9. #9
    Join Date
    Mar 2020
    It appears to be working OK for lots of discs. There are still a lot of discs that are not showing artwork which I would expect to appear. For example "NOW that's what I call Music 104".
  10. #10
    Join Date
    Apr 2002
    That is a relatively new release and typically artwork can take a few weeks to appear, however if you click the album art section to manually search for the image.
  11. #11
    Join Date
    Feb 2013
    I'm having the same problem with three recent CD's. No meta data or album art for any of them. I also tried with a CD purchased in February 2020. Album art did not automatically appear. I had to right click the ellipse and choose from the internet.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
