C drive fills when ripping to external hard drive
  • AllenC
    • Dec 2017
    • 10
    Hello,
    I am using a Windows 7 PC machine (still) as the built in CD/DVD player has done a very good job of ripping using CD Ripper. I have been very satisfied with Release 16.4, which I am using.
    My problem is that despite successfully ripping to an external hard drive, for some reason, my C drive is filling up and being that is nearly full, eventually it fills and I have to continually find data to purge, move elsewhere and uninstall programs. This is not sustainable and I have another couple hundred CD’s to rip still.
    An example is a typical classical CD that I just ripped; about 400 MB, caused a decrease in C drive available capacity by more than that amount. Strange. And I am only ripping CD’s with that computer, no other activity.
    Any suggestions would be greatly appreciated. And by the way, I couldn’t find any related posts on the forums.
    Many thanks,
    Allen
    • 43917
    Re: C drive fills when ripping to external hard drive
    Which encoder are you using?
    In a Windows File Explorer type into the address bar:
    %tmp%
    see if files are left in there after ripping
    You should update to R16.6 there could have been a bug which has long been fixed (R16.4 is around 2 years old).
    • AllenC
      • Dec 2017
      • 10
      Thank you for your reply, Spoon.
      No, there are no files left there in Temp. And yes, I will update, thanks.
      Please excuse my ignorance. I don’t know which encoder. Please advise how to find out.
      Allen
        • 5744
        Please excuse my ignorance. I don&*8217;t know which encoder. Please advise how to find out.
        Allen
        by encoder he means, what files are you creating? mp3, FLAC, WAV, ALAC, m4a, etc.
        • AllenC
          • Dec 2017
          • 10
          FLAC.
          • AllenC
            • Dec 2017
            • 10
            Will my settings/configurations be maintained upon upgrading to D16.6?
            Thank you.
              • 43917
              Yes
              • AllenC
                • Dec 2017
                • 10
                In order to upgrade to R16.6, please confirm that the "Install Registered Software" button on the Registration Retrieval page of your website is the correct one to select. And that one will maintain my settings/configurations?
                Thank you.
                  • 43917
                  Yes is correct, settings are not lost.
