Results 1 to 8 of 8
Thread: dbpoweramp Sometimes, But Not Always, Doubles The Stored Rating
  1. #1
    Join Date
    Oct 2005
    Location
    PA
    I have most of my audio files containing a rating within the tags. The rating is stored as an integer from 1 to 5. dbpoweramp will sometimes multiply this value by two. It does not always do this though. I am not sure why it does this at all.
    Attached is an example screenshot.
    The tag content within the file is RATING=5.
  2. #2
    Join Date
    Apr 2002
    Re: dbpoweramp Sometimes, But Not Always, Doubles The Stored Rating
    dBpoweramp Control Centre >> Audio Codec Options
    there you can set the range for FLAC rating.
  3. #3
    Join Date
    Oct 2005
    Location
    PA
    This is how it is currently set in my options. I have never changed this:
    This is the latest reference version of 16.6.
  4. #4
    Join Date
    Apr 2002
    Perhaps the file you are looking at is stored internally on a rage 0-20 that is why it is showing 0-10 because it halves the stored value.
  5. #5
    Join Date
    Oct 2005
    Location
    PA
    This actually has happened to me quite a bit with many files.
    Here is the particular file in Tag&Rename:
    Attachment 2639
    Here is the tag info shown in a hex editor:
    Attachment 2640
    As stated in my initial post, the rating shows as RATING=5. The question is how is dbpoweramp displaying a rating of 10? This happens quite often.
  6. #6
    Join Date
    Oct 2005
    Location
    PA
    The issue has to do with stored lyrics in the tag. If I remove the lyrics, dbpoweramp displays the rating properly. If I re-add the lyrics, it displays the rating incorrectly again as 10.
  7. #7
    Join Date
    Apr 2002
    Please send one file with lyrics which shows this to:
    https://www.dbpoweramp.com/email.htm
  8. #8
    Join Date
    Oct 2005
    Location
    PA
    I just emailed the same example file from my screenshots.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
