Upgrade Process Recommendations
  • JohnnyK
    • Jan 2020
    I'm currently using dbPoweramp CD Ripper R14.2 and I want to upgrade to the current version. I want to save my current settings and ripping profiles. Can you provide recommendations on how to do this or are they saved automatically when I upgrade to R16?
    I've seen a couple of other posts like this on going from 14 to 15 which said settings are lost and you have remove 14 before installing 15. Then I saw a post on upgrading from 15 to 16 which said that settings are carried over automatically.
    Thanks for any pointers or guidance on this.
    Best,
    --John
    • 43898
    Re: Upgrade Process Recommendations
    You can uninstall the old version, then install the new version, no settings are lost.
