Monkey's Audio Verification Errors
  • KnightFallen
    • Apr 2016
    I tried to verify Monkey's Audio files created by dBpoweramp (release 13 v4.38) with Monkey's Audio v5.11 x64. I have been getting errors on all full description verification and sometimes quick verify MD5 errors. What is going on?
    • 43919
    Re: Monkey's Audio Verification Errors
    All tracks or some?
    • KnightFallen
      • Apr 2016
      I have to do more checking, since I just did a spot check and found the error. So far, 2-channel 16/44.1 checks out on the handful I have checked. I am getting errors on 2-channel 24/96 content.
      • Jamil
        • Oct 2005
        • 45
        Monkey's Audio has well known limitations supporting any audio format greater than 16-bit 48KHz. For high def audio, you are better off using FLAC or anything else other than Monkey's Audio.
