Raspberry Pi Asset UPnP upgrade from 6.2 to 6.3
  • RaspberryAsset
    • Feb 2018
    • 40
    Hello all
    Is there an upgrade process from 6.2 to 6.3 or do we have to do a complete reinstall and start afresh?
    • 43923
    Re: Raspberry Pi Asset UPnP upgrade from 6.2 to 6.3
    Copy the install files over the top of the existing (shutdown asset first) to upgrade and not lose any settings.
    • RaspberryAsset
      • Feb 2018
      • 40
      Hi Spoon
      Thanks for the quick reply.
      Is my install messed up or non-typical
      pi@raspberrypi:~ $ cd Asset
      pi@raspberrypi:~/Asset $ ls
      Asset-R6.2-Linux-ARM32-registered
      pi@raspberrypi:~/Asset $ cd Asset-R6.2-Linux-ARM32-registered
      pi@raspberrypi:~/Asset/Asset-R6.2-Linux-ARM32-registered $ ls
      bin
      pi@raspberrypi:~/Asset/Asset-R6.2-Linux-ARM32-registered $ cd bin
      pi@raspberrypi:~/Asset/Asset-R6.2-Linux-ARM32-registered/bin $ ls
      asset-120x120.png asset.css AssetImages AssetReg.bin AssetUPnP Versions
      pi@raspberrypi:~/Asset/Asset-R6.2-Linux-ARM32-registered/bin $ ./AssetUPnP
      So when you mentioned to do an install over the old version, within this directory?
        • 43923
        Yes in that folder, if you unzip the .gz file, then it might have a different folder structure.
