Results 1 to 12 of 12
Thread: Help setting up AssetUPnP on Raspberrypi
  1. #1
    Join Date
    Aug 2015
    Hoping for some help - About 5 years ago I bought a raspberrypi and successfully managed to setup and run Asset on it. However it recently stopped working - the pi just sat there with the light on but no other evidence of life - so I decided to wipe the SD card and start again. This seemed to solve the problem of the pi being dead, but setting it up again this time I can’t for the life of me seem to get Asset working!
    I’ve followed Spoon’s instructions as far as I can tell, but Asset isn’t finding any music. This is the line I have at the end of the /etc/fstab file:
    //192.168.1.66/Public /home/pi/nas cifs guest,_netdev,sec=ntlm 0 0 (the NAS has a fixed IP)
    And on the configuration page of Asset I have /home/pi/nas in the ‘Watched media folders’ box.
    My knowledge of Linux is basically zero outside of Spoon’s instructions, although I did manage to get it working last time!
    Any help would be very much appreciated (please spare me from having to use the inbuilt Twonky server on my NAS!)
    Phill
  2. #2
    Join Date
    Dec 2013
    Re: Help setting up AssetUPnP on Raspberrypi
    Is the RPi mounting the NAS volume?
    Where the mount command being executed?
    Have you created the directory in \home\pi\nas on the RPi and applied the right permissions?
    If you open a command shell, can you navigate to this directory and &*8216;see&*8217; the contents of the volume on the NAS volume?
    Once Asset can &*8216;see&*8217; the folders to scan, it does the rest.
  3. #3
    Join Date
    Aug 2015
    Thanks simes_pep,
    Is the RPi mounting the NAS volume? - I’m afraid I don’t know - how would I find this out?
    Where the mount command being executed? - /etc/fstab? Or have I got the wrong end of the stick?
    Have you created the directory in \home\pi\nas on the RPi and applied the right permissions? - I entered these lines, as per Spoon’s instructions:
    cd /home/pi
    sudo mkdir nas
    sudo chmod 777 nas
    Does that answer your question?
    If you open a command shell, can you navigate to this directory and ’see’ the contents of the volume on the NAS volume? - does this tell you anything:?
  4. #4
    Join Date
    Aug 2015
  5. #5
    Join Date
    Apr 2002
    It does not look mounted, ls -l would list all the folders on the nas.
    Does your nas not require a password? cifs is based on passwords unless the guest account is active.
    NFS is another linux methos of sharing, based on ip addresses allowed.
  6. #6
    Join Date
    Dec 2013
    No if you run a df or even a du command it should give you the usage of the mounted file store
    Where are you running a sudo mount -a command to actually execute on the contents of the fstab file?
  7. #7
    Join Date
    Aug 2015
    Quote Originally Posted by simes_pep View Post
    As far as I’m aware, I’m not!
    Could you suggest where I should be, and what such a command may look like?
    I would probably be giving up at the point if it wasn’t for the fact that I have had it running before!
  8. #8
    Join Date
    Dec 2013
    Type crontab -e
    Enter
    @reboot sudo mount -a
    Then reboot
    I found that later versions of rasbian stopped automounting what was listed in the fstab file.
    I then rebuild my RPi to DietPi, as my existing version was stuck back in Jessie/Wheezy and I wanted to move to Stretch/Buster versions.
  9. #9
    Join Date
    Aug 2015
    I am getting somewhere in that I have managed to manually mount the NAS volume by typing the line:
    Sudo mount //192.168.1.66/Public /home/pi/nas
    and Asset then sees my music and I can play it!
    However, it’s not auto mounting it on a reboot. I have added the line ‘@reboot sudo mount -a’ to the crontab file, but not much seems to be happening.
  10. #10
    Join Date
    Aug 2015
    Oh dear, thought I was getting somewhere, and then on a reboot nothing happened, so I plugged the pi into the TV and it came up with this:
    This likely to be something I’ve done, or a faulty pi?
  11. #11
    Join Date
    Dec 2013
    Sorry, thats a new one to me.
    What OS are you running on the RPi?
  12. #12
    I may have something similar happening. I got it to work by using the rescan detecting changes options.
    If I use rescan all, no media gets detected.
    Let me know if this works for you.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
