Results 1 to 6 of 6
Thread: Higher sample offset = worse drive?
  1. #1
    dBpoweramp Enthusiast Nubben's Avatar
    Join Date
    Apr 2008
    Location
    London, UK
    Hi all,
    Will a higher sample rate offset (say +667) make for a worse accurate drive than a +6 sample offset drive?
    Thanks!
    Henrik
  2. #2
    Join Date
    Feb 2014
    Re: Higher sample offset = worse drive?
    The offset is specific for a drive. AFAIK without the right offset for your drive you will not achieve an accurate rip (a different checksum).
    Join Date
    Nov 2007
    Location
    Florida, USA
    Quote Originally Posted by Nubben View Post
    Hi all,
    Thanks!
    Henrik
    No.
  4. #4
    Join Date
    Feb 2014
    Maybe I understood the question in a different way than Gary. Maybe my limited english is the reason why.
    If CD Ripper indicates an accurate rip, the rip is accurate and the offset and the drive do not matter at all.
    But if you configure a wrong offset for your drive, I think that you will not be able to get an accurate rip (I understood the question that way around).
    What you think Gary?
    Join Date
    Nov 2007
    Location
    Florida, USA
    Quote Originally Posted by Dat Ei View Post
    Agree with you Dat Ei. There is no fundamental reason why larger offset affects rip quality. Of course drive should be set up properly as you note.
  6. #6
    Join Date
    Apr 2008
    Location
    London, UK
    Thank you both for taking your time. I am struggling to get my head around this particular drive I have purchased - have another thread going here as well: https://forum.dbpoweramp.com/showthr...ns-please-help!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
