Results 1 to 2 of 2
Thread: Metadata taking very long to load
  1. #1
    Join Date
    Aug 2019
    Question Metadata taking very long to load
    Hi, My metadata is taking forever to load: 5-10 min per cd. Mac mini, Mojave OS. This only started 2 days ago. I have uninstalled the program and reinstalled, I think I am running the most recent version R16.5 and I don't have anything from AMG checked.
    Can anyone suggest a solution?
    Thank you,
    Mike
  2. #2
    Join Date
    Dec 2008
    Location
    London, UK
    Re: Metadata taking very long to load
    Un-check all sources and then try each source, one at a time and see if this helps isolate the issue.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
