Weird problem - some tracks do not copy to iTunes
  • Hitarth
    • Sep 2017
    • 151
    hi,
    I have ripped a CD and received a report all tracks ripped accurately (attached report. I tried to copy the tracks to iTunes ( dragging the folder to iTunes ) I have only some tracks copied. on checking the files, I have some files with errors & some are ok. pls find attached screen shots
    Log.txt
ID:	297397Click image for larger version
ID:	297398Click image for larger version
    pls notice the remark on the preview pane on the right
    • 4015
    Re: Weird problem - some tracks do not copy to iTunes
    Perhaps those files are locked by a process. Reboot your device and try importing into iTunes again.
      • 1745
      Did you check the length of the path of those missing files? The path looks quiet long.
      • Hitarth
        • Sep 2017
        • 151
        yes, you were right !! thanks
        I copied the folder to the desktop & re copied the files … many thanks
        • Hitarth
          • Sep 2017
          • 151
          hi
          I tried this & it did not work
          tried what Dat Ei suggested .. it worked ..
          many thanks for your time
