Results 1 to 4 of 4
Thread: SHN Codec Installation problem
  1. #1
    Join Date
    Jun 2012
    Going through some old music files that are SHN encoded. Wanted to convert them, but did not have the SHN codec installed. After downloading, I received an error, just a general error message, during installation. I have windows 10 system and have version 16.6 of dBpoweramp installed. Tried to install a second time, and it did say I have the SHN codec installed but same error message: 'Error whilst running 'C:\Program Files(X86)\Illustrate\dBpoweramp\dBConfig.exe'.
    Any suggestions on what I'm doing wrong?
  2. #2
    Join Date
    Apr 2002
    Re: SHN Codec Installation problem
    It is 32 bit only, you would have to uninstall dBpoweramp, and force the 32 bit version of dBpoweramp to install. Then when done uninstall all and reinstall 64 bit version.
    See:
    https://forum.dbpoweramp.com/showthr...-Compatibility
  3. #3
    Join Date
    Jun 2012
    Thanks Spoon ... sounds like too much work. Maybe these old files aren't worth the effort unless I find several that need converting.
  4. #4
    Join Date
    Nov 2007
    Location
    Florida, USA
    You might just want to install foobar2000 and the shn conversion component. You can use this to convert your shn to FLAC without having to mess about with your dbpa installation.
    Install foobar2000 from here:
    https://www.foobar2000.org/download
    Then install the shn conversion component from here:
    https://www.foobar2000.org/component..._input_shorten
Posting Permissions
  • You may not post replies
  • You may not edit your posts
