NOTE: Any posts to this forum on or after 16th April will disappear in few days when we transition to a new forum
Results 1 to 6 of 6
Thread: AssetUPnP on Raspi. UPnP Control points show error after selecting library
  1. #1
    Join Date
    Jul 2019
    I'm using AssetUPnP on a Raspberry Pi with Libreelec for years without any problems. But now all UPnP control points (BubbleUPnP, Asset Control) show errors after selecting the library. 'Asset Control' shows 'Unable to retrieve listing' BubbleUpnP shows 'Connection error (501)'.
    - Version: R6.2 [Linux-ARM32]
    - The configuration of the Asset server (xxx.xxx.xxx.xxx:45537) is OK.
    - Browse tree reset to default.
    - Library contains 15068 tracks in 1061 albums.
    - UPnP Logs are showing no errors.
    What is going wrong. Has anyone an idea?
    Thanks in advance
    Manfred
  2. #2
    Join Date
    Apr 2002
    Re: AssetUPnP on Raspi. UPnP Control points show error after selecting library
    Check you do not have multiple IP addresses on the Pi
  3. #3
    Join Date
    Jul 2019
    Only one IP-Address
    Manfred
  4. #4
    Join Date
    Apr 2002
    In Asset configuration is a debug option, enable it, restart asset then try to connect to asset, and see what is in the debug log.
  5. #5
    Join Date
    Jul 2019
    Spoon,
    thats's what is to find in the debug Log
    19:21:40] UPnP debug log opened
    [19:21:40] Date: 2019-07-04
    [19:21:40] R6.2 [Linux-ARM32]
    [19:21:40] Asset install location: /storage/asset/Asset-R6.2-Linux-ARM32-registered/bin/
    [19:21:40] Home folder: /storage
    [19:21:40] Asset data location: /storage/.dBpoweramp/uMediaLibrary-v4
    [19:21:40] PID: 14852
    [19:21:40] Linux LibreELEC 4.19.36 *1 SMP Sat May 4 17:23:44 CEST 2019 armv7l GNU/Linux
    [19:21:40] 1 media folders specified:
    [19:21:40] /var/media/My Passport/Music/
    [19:21:40] No playlist folders specified
    [19:21:40] ContainerAddToCache: added :: 0\ [Seg: 0x7AF0F86341859D3D]
    [19:21:45] UPnP debug log opened
    [19:21:45] Date: 2019-07-04
    [19:21:45] R6.2 [Linux-ARM32]
    [19:21:45] Asset install location: /storage/asset/Asset-R6.2-Linux-ARM32-registered/bin/
    [19:21:45] Home folder: /storage
    [19:21:45] Asset data location: /storage/.dBpoweramp/uMediaLibrary-v4
    [19:21:45] PID: 14922
    [19:21:45] Linux LibreELEC 4.19.36 *1 SMP Sat May 4 17:23:44 CEST 2019 armv7l GNU/Linux
    [19:21:45] 1 media folders specified:
    [19:21:45] /var/media/My Passport/Music/
    [19:21:45] No playlist folders specified
    [19:21:45] ContainerAddToCache: added :: 0\ [Seg: 0x7AF0F86341859D3D]
    [19:21:50] UPnP debug log opened
    [19:21:50] Date: 2019-07-04
    And so on.
    Manfred
  6. #6
    Join Date
    Jul 2019
    I solved the problem by uninstalling Asset, deleting all related directories and files.
    Then made a new installation.
    Manfred
Posting Permissions
  • You may not post replies
  • You may not edit your posts
