Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
Thread: CD Drive Accuracy 2019
  1. #16
    Join Date
    Nov 2007
    Location
    Florida, USA
    Re: CD Drive Accuracy 2019
    Quote Originally Posted by Nubben View Post
    Gary, would you think buying the ASUS TurboDrive BW-16D1H-U_PRO instead of going down the enclosure route would be a good idea? Will that make a difference? Or will all USB attached devices have issues with C2s?[/COLOR]
    I really don't know the answer to this (the drive or whether all USB connected drives don't work with C2). I've never looked at the list of top drives. I come from the approach, of "having several cheap drives combined with AR" is all I need for 99.9% of my ripping. The other .1% I don't worry about.
  2. #17
    dBpoweramp Enthusiast Nubben's Avatar
    Join Date
    Apr 2008
    Location
    London, UK
    Understood Gary! Sounds like a sound approach. Many thanks for your advice.
  3. #18
    Join Date
    Nov 2007
    Location
    Florida, USA
    yep, no pun intended.
  4. #19
    Join Date
    Feb 2013
    Location
    Mesa, AZ
    So are there a couple of external drives that are good performers on the lists that I can use with my MacBook?
  5. #20
    Join Date
    Sep 2019
    Location
    Toronto, Canada
    Quote Originally Posted by mwheelerk View Post
    I'd like to know the same thing but for use with a PC. Thanks!
  6. #21
    Join Date
    Oct 2018
    Many thanks for posting the results for 2019.
    All my cd drives are included in the offset listing on the website, but two are missing from the CD Drive Accuracy 2019 listing, and may be in earlier listings.
    Is there any way to obtain the accuracy data for the two drives ( LG Electronics / HL-DT-ST DVDRAM GE24NU40; TSSTcorp CDDVDW SE-208BW )
  7. #22
    Join Date
    Apr 2002
    If the drives do not have enough submissions then they are not included.
  8. #23
    Join Date
    Nov 2019
    Could anyone point me to the drive that got the best score and is an internal 9,5 mm thick BD burner for laptop?
    And if I should still pursue LTR-40125S for obvious reasons and if they are not obvious I can link to why they should be?
  9. #24
    Drive: Lenovo - Slim_USB_Burner (74 users): Submissions: 575 accurate, 6 inaccurate, 98.9673 % accuracy
    Which model is this?
    I know there are 2 lenovo external usb drive.
    Which model is it? 1st or 2nd picture?
  10. #25
    Join Date
    Apr 2002
    As drive offsets are from peoples submissions we cannot say which drive it is.
  11. #26
    It got pretty good result. I going to get the 2nd one, I assume the 1st one is ThinkPad ultra slim dvd. Thanks anyway. PerfectTUNES is needed right for accuraterip?
  12. #27
    Join Date
    Nov 2007
    Location
    Florida, USA
    Quote Originally Posted by metrogeeky View Post
    PerfectTunes can compare previously ripped files to the AR database. But dbpoweramp CD ripper (different program) uses AR in the ripping verification process.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
