Batch Converter copy DSF without conversion?
  • Darryl R
    • Jul 2014
    • 99
    Is there a way to convert FLACs and ONLY copy DSF (no conversion) to the dest?
    • 43902
    Re: Batch Converter copy DSF without conversion?
    Conditional Encoding DSP effect should do this.
    • Darryl R
      • Jul 2014
      • 99
      Almost there. I also have the DSP effect to keep the artwork, but it doesn't keep the artwork of the DSD (DSF) albums it copies.
        • 43902
        I am not sure how you can do that.
        • Darryl R
          • Jul 2014
          • 99
          Would be a nice to have. It makes logical sense that if you only copy certain albums, you would want folder.jpg copied as well. Going thru and manually copying the jpg is more error prone than just copying entire folder.
