Results 1 to 7 of 7
Thread: HDCD Errors
  1. #1
    Join Date
    Jun 2019
    Location
    des moines iowa
    HDCD Errors
    I am trying to rip a cd So What Jerry Garcia & David Grisman I get error codes saying it cant write to output location, I have ripped other HDCDs without issue
    My question is where is the error manual located so I can lookup the error codes?
    Join Date
    Apr 2002
    Re: HDCD Errors
    Check the location you are writing to exists and can be written to.
  3. #3
    Join Date
    Jun 2019
    Location
    des moines iowa
    Re: HDCD Errors
    Thanks I have checked everything seems ok, still wont ripped I dont change anything cd to cd
    When try and recopy other CDs I get the warning message are you sure you want to over right
    Ill keep looking
  4. #4
    Join Date
    Feb 2014
    Re: HDCD Errors
    Please copy and paste the error message into a posting. My guess is that you have a naming problem.
    Join Date
    Jun 2019
    Location
    des moines iowa
    Re: HDCD Errors
    Information converting to Wave, 'Track 4' to '/Volumes/Mach2 Music/Jerry Garcia/So What/04 Jerry Garcia - 16-16Jazz.wav'
    Track 4: Ripped LBA 106062 to 134432 (6:18) in 1:02. Filename: /Volumes/Mach2 Music/Jerry Garcia/So What/04 Jerry Garcia - 16-16Jazz._
    AccurateRip: Accurate (confidence 71) [Pass 1]
    CRC32: 69EA8B94 AccurateRip CRC: C4B2E72F (CRCv2) [DiscID: 008-0013401d-008135a1-770f0508-4]
    AccurateRip Verified Confidence 71 [CRCv2 c4b2e72f]
    AccurateRip Verified Confidence 43 [CRCv1 cf72049b]
    AccurateRip Verified Confidence 5 [CRCv2 a6f6f817], Using Pressing Offset +12
    AccurateRip Verified Confidence 3 [CRCv1 b3ac4855], Using Pressing Offset +12
    HDCD Track Detected
    Error converting to Wave, 'Track 4' to '/Volumes/Mach2 Music/Jerry Garcia/So What/04 Jerry Garcia - 16-16Jazz.wav'
    Error: Unable to create output folder '/Volumes/Mach2 Music/Jerry Garcia/So What/', error code: 13. [dBCoreConverter]
    Thank You
  6. #6
    Join Date
    Nov 2007
    Location
    Florida, USA
    Re: HDCD Errors
    dbpa doesn't seem to have rights to write to the disk on the "volumes/Mach2 Music/ drive. (this has nothing to do with HDCD....it is all about rights to write to the disk).
    p.s. Great album by the way.
  7. #7
    Join Date
    Jun 2019
    Location
    des moines iowa
    Re: HDCD Errors
    I like a lot of Grismans stuff
    I've been ripping like crazy the last few days, this is the only cd having issues
    I'll figure it out, at times I miss the days when you put a cd in a tray
Posting Permissions
  • You may not post replies
  • You may not edit your posts
