Problem in ripping to wav
  • fleche
    • May 2019
    Hello,
    Since the end of march, everytime i try to rip CD to wav, i have the message below a few seconds after i begin to rip:
    "Error ripping to Wave, 'Track 2' to 'G:\Container\Musique\CD Extraction\Lee Fields & The Expressions\It Rains Love\02 Lee Fields & The Expressions - Blessed With The Best (Instrumental).wav'
    Error unable to open File 'G:\Container\Musique\CD Extraction\Lee Fields & The Expressions\It Rains Love\02 Lee Fields & The Expressions - Blessed With The Best (Instrumental).wav' for writing. [clEncoder::BeginConversion] "
    i installed the program again, but nothing changes
    i have the 15.3 version and it worked perfectly untill then. it works well when i rip with windows media player
    what could be the problem? Thanks
    • 5744
    Re: Problem in ripping to wav
    What is G drive.is it a NAS. I suspect the program doesn&*8217;t have rights to write to that drive.
    • fleche
      • May 2019
      Hello garym,
      Thanks for your answer, it helps me to understand that the G: letter was the name of the external drive i used before, but now this drive in on D: letter, i change the path and now it works. I should have think about that before.
      thanks again
        • 5744
        Great.
