; semi-colon truncating when using Converter
  • Nubben
    • Apr 2008
    • 154
    Hi Spoon, all,
    I have browsed the forum and although I have seen the semi-colon issue in tags I have not seen any posts with my problem.
    I have recently moved to Roon and am fiddling around with new tags I was not able to add in iTunes. I currently use ALAC files exclusively and am on macOS Mojave using dBpa 16.5.
    If I need to amend a tag in an ALAC file after I have added it to my Roon music library I right-click on it and choose "Edit with dBpa". The edit window launches and I add (in this case) two remixers separated by semi-colon. See image 1 below:
    Image 1
    [IMG][/IMG]
    I click ok to apply it but when launching the Edit window again the last remixer's name has disappeared see Image 2 below.
    Image 2
    [IMG][/IMG]
    Is this a tagging limitation? I have replicated this issue in- and outside of my Roon library. Roon does not alter any files anyway however.
    Many thanks
    Nubben
    • 43926
    Re: ; semi-colon truncating when using Converter
    Looks like a bug, will look ASAP.
    • Nubben
      • Apr 2008
      • 154
      Hi Spoon!
      Many thanks for that. It could be the ALAC code that's causing this as I have tagged a couple of FLAC files and those tags stick? But NOT on the ALAC files applying the same tags.
      Nubben
