Results 1 to 8 of 8
Thread: Batch converter max speed of i7 8700k vs. i7 9700k?
  1. #1
    Join Date
    Mar 2019
    Question Batch converter max speed of i7 8700k vs. i7 9700k?
    Hi guys I wonder if any of you would happen to know how much of a conversion speed does a i7 8700k cpu with 16gb or ram would reach in conversion speed?
    I happen to have i7 9700k which does not have hyperthreading so its 8 physical cores. Music is on external usb3 hdd and conversion destination is a 3.5 wd blue hdd. The highest I got was around x450 speed sometimes less.
    Im wondering a lot if got better results if I went for i7 8700 with 6 cores and 6 ht cores making a total of 12 cores.
    1st world problems, right?
  2. #2
    Join Date
    Apr 2002
    Re: Batch converter max speed of i7 8700k vs. i7 9700k?
    What are you converting from and to?
  3. #3
    Join Date
    Mar 2019
    Mostly from flac to m4a.
  4. #4
    Join Date
    Apr 2002
    When encoding on your current system, all cores show 100% usage?
  5. #5
    Join Date
    Mar 2019
    Like this?
  6. #6
    Join Date
    Apr 2002
    That CPU graph perhaps averages out to 75%, a faster CPU will not help, the HDD is the slow part.
  7. #7
    Join Date
    Mar 2019
    are you sure? even if there was hyper-threading involved which could do 12 songs at the time the overall speed would still be pretty much the same?
  8. #8
    Join Date
    Feb 2014
    If the cpu would have been the limiting factor, you would have seen a cpu usage nearly at 100%.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
