wave to mp 3, result: mp3 sounds terrible, win 10 64 bit;db Power amp Vers 13.5
  • login23
    • Mar 2019
    What can I do ?
    • 43926
    Re: wave to mp 3, result: mp3 sounds terrible, win 10 64 bit;db Power amp Vers 13.5
    Which settings are you using for mp3?
    • login23
      • Mar 2019
      Have tried VRB and the others too, same result.
      As a test have tried converting wav to flac all is fine.But back to mp 3, bad.
        • 43926
        Which audio player are you using?
        What frequency have you set for the mp3?
        • login23
          • Mar 2019
          Audio Player: Groove Musik (Win 10 intern), but with win media player its the same.
          Frequency in db Power Amp - 16 kHz
            • 43926
            There is your problem, it should be 44KHz to match the source.
            • login23
              • Mar 2019
              Thanks a lot. Have changed and tested. Everything is fine.
