Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: File will not convert to MPC
  1. #16
    Join Date
    Apr 2002
    Re: File will not convert to MPC
    1) It must have been the filename which matched somehow.
    2) No, by default all drives have this enabled, switching it off can break apps. It is how Unicode is supported with encoders which are not Unicode compatible.
  2. #17
    Join Date
    Dec 2018
    OK thank you for that. Just so you know, I have never disabled short filenames. This, my backup PC and my laptop all have NtfsDisable8dot3NameCreation=2. I set it to 0. Also I cannot believe we would ask a non-technical person to have to go into the registry and change things.
  3. #18
    Join Date
    Apr 2002
    A value of 2 means it is controlled on a per volume basis, which is default and correct. FSUTIL can be used to enable or disable a single volume, by default it is enabled for all drives and volumes.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
