DSD to PCM conversion buggy
  • Kempy
    • Dec 2018
    • 11
    Tried to use Music Converter, v16.5, 32bit, DSD Decoder set to 352kHz (DXD), for the DSD64 to 24bit-88.2kHz conversion, but found it not really working well.
    1.)
    The DSD demodulator seems to be buggy. There is a high level click in the right channel at the end of every converted file. I have to trim 20ms at the end to get rid of that.
    2.)
    I'm using a VST EQ to perform low pass filtering at 30kHz but none of the various 32bit VST plugins tested does have any effect/seems to be working. Is the VST support broken in v16.5 ?
    G.
    • 43926
    Re: DSD to PCM conversion buggy
    dBpoweramp is 64 bit, so 32 bit VST will not work.
    It is likely the click at the end is because someone has written some kind of non standard tag to the end of the DSD.
    • Kempy
      • Dec 2018
      • 11
      I do have a 32bit installation of dBpoweramp and do all my tag edits with dBpoweramp.
      G.
        • 43926
        Try removing the tag as a test and see if still clicks.
        Have you looked in an audio editor what the click looks like?
        • Kempy
          • Dec 2018
          • 11
          I did some test conversions, DSD64 (*.dsf) files with cleared tags to wave 32bit floating point at 352,8kHz and the click (0dB FS) in the right channel comes up.
          To me that looks like a switching click, in special with that high amplitude.
          Converting the same source files with JRiver MC did not show this issue.
          G.
          • Kempy
            • Dec 2018
            • 11
            2nd Pic
              • 43926
              Sorry I do not know what to suggest, we did not write the DSD decoder.
              • Kempy
                • Dec 2018
                • 11
                Is the DSD decoder sox-DSD based ? I found the same behave when converting DSD64 to PCM with sox-DSD.
                I switched to Foobar with the new SACD plugin for such conversions, that works fine.
                G.
                  • 43926
                  It is possible they both use the same decoder yes.
