Products            Buy            Support Forum            Professional            About
Results 1 to 4 of 4
Thread: CD Drive sample offset question [Mac]
  1. #1
    Join Date
    Oct 2018
    Just start using dBpoweramp, running Mac OS 10.13.6 on a 2014 Mac Book Pro, and using an Apple USB SuperDrive.
    In configuring Accurate Rip settings, a dialog window popped up along the lines of the drive isn't recognised, would you like to enter a manual offset (not entirely sure of the details), which I left at 0.
    Having a bit of a Google it seems that the offset should be +6. Having ripped several CDs the log files show a consistent pressing offset of +6 it would seem to support that (assuming these are related, this is all new to me so if I'm spouting nonsense please forgive my lack of knowledge!).
    Is this something that I can manually adjust? Or clear dBpoweramp's record of the drive to allow me to configure it again? Or is it something I don't need to worry about in the first place as Accurate Rip seems happy enough?
    Many thanks.
  2. #2
    Join Date
    Apr 2002
    Re: CD Drive sample offset question [Mac]
    If you are confident then enter -6, however 6 samples are in-audible and accuraterip works without you entering this value, so nothing really is gained or lost from either way.
  3. #3
    Join Date
    Oct 2018
    Thanks for your reply. How would I edit this, the value looks to be "locked in" in the software?
  4. #4
    Join Date
    Apr 2002
    It cannot be edited.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
