Fraunhofer mp3 encoder not working in dbpoweramp 14
  • CyndiBop
    • Feb 2018
    • 11
    Hello!
    It's strange but I've always used it successfully also in my Windows 10 64-bit PC. Today when I convert a lossless track to mp3 fraunhofer it converts in less than a second and the file is just a few kb. Obviously the converted file isn't playable.
    What can I do?
    Are there any more recent version of dbpoweramp with the fraunhofer mp3 encoder?
    Thanks for assistance.
    • 43915
    Re: Fraunhofer mp3 encoder not working in dbpoweramp 14
    Possibly your security software is blocking the encoder?
    • CyndiBop
      • Feb 2018
      • 11
      hmmm I don't think so... it's the same security software with the same settings. I recall I used it in my HP WIN10 PC, but I'm not sure at 100%. There's not any exe file for the fraunhofer encoder... just a dll.. is it normal?
      I'm sorry because I love fraunhofer and it's the main reason I use the excellent dbpoweramp software over any other.
        • 43915
        Yes it is a Dll, something has changed on your system to block it.
        • CyndiBop
          • Feb 2018
          • 11
          I solved it!! There was the lenght split effect enabled, and the error was that it was impossible to load it... I removed it and it converted perfectly! So glad!!
          • kishimoto
            • Oct 2016
            can i ask why?
            i think lame is better.
