Codec Issues
  • Trickster
    • Jun 2018
    Codec Issues
    Hello Everyone
    I'm having problems trying to convert files to wav or any other format. I've got wav codec installed which has resulted me having to use Audacity to do the ones it couldn't convert. I've purchased this software with intention to use for my music needs but I'm really beginning to lose hope with it as it's not fulfilling my needs. If anyone can help me in any way I would be very grateful as it's really infuriating me.
    thanks
    • 1748
    Re: Codec Issues
    Which OS? Which dBpa version? Which codec for the source files? What error message?
    • Trickster
      • Jun 2018
      Re: Codec Issues
      Hi thanks for responding to this post when you had a spare moment
      The OS I'm using is Windows 10 and the dBP I'm using is a purchased one. I've also downloaded the wavpack codec which is a release 12.
      The messages I keep getting are as below:
      Error converting to Wave, 'C:\Users\Trickster\Desktop\SG archive\Bucketheads - tha bomb (bootleg remix).mp3' to 'C:\Users\Trickster\Desktop\New folder\Bucketheads - tha bomb (bootleg remix).wav'
      Error decoding mp3 data stream, is corrupt?
      Error converting to Wave, 'C:\Users\Trickster\Desktop\SG archive\OJ - Saw (Bass Mix).wma' to 'C:\Users\Trickster\Desktop\New folder\OJ - Saw (Bass Mix).wav'
      Error: Unable to load decoder for file type '.wma', codec not installed? visit 'Codec Central'. [dBCoreConverter::dBCoreConverter]
      Error converting to Wave, 'C:\Users\Trickster\Desktop\Niche and Capitol Classics\desktop.ini' to 'C:\Users\Trickster\Desktop\Niche and capitol\desktop.wav'
      Error: Unable to load decoder for file type '.ini', codec not installed? visit 'Codec Central'. [dBCoreConverter::dBCoreConverter]
      they're the messages I keep getting it's only a select few I'm pretty lost on what else to do next.
        • 1748
        Re: Codec Issues
        Recently bought? So it is a registered version of R16? Which one exactly?
        That looks like the source file is cprrupted.
        Can you play that file with WMP?
        desktop.ini isn't a audio file at all...
          • 1748
          Re: Codec Issues
          Update: Did you install the WMA codec from that site?
          • Trickster
            • Jun 2018
            Re: Codec Issues
            The release version is the 16.4 it doesn't say I need to update it as that icon isn't highlighted.
            Yup on the official website itself. The ones that I'm having trouble trying to convert still plays on WMP
            the desktop.ini It's saved in a folder on my desktop could that have anything to do with it?
            is there a way to fix corrupted music files? as it plays fine in windows media player
            Trickster
              • 1748
              Re: Codec Issues
              Ok, but did you install that additional codec for WMA?
              I've just checked it on my PC. I could play a WMA file, but without the additional codec I couldn't convert the WMA file.
              IMHO no. Just exclude that file from the conversion.
              The fact that you can play that file does not mean that it is ok from the point of view of the standard.
              • Trickster
                • Jun 2018
                Re: Codec Issues
                I've just been on that list you've gave me and pointed to the ones necessary. I've just downloaded the Windows Media Codec 9 to see if that does any difference. I'm just going to do it with every codec that I might come across as a precaution.
                also could be effect on how the music is ripped? As I do own quite a lot of tunes ripped from vinyl?
                  • 1748
                  Re: Codec Issues
                  Ok. If you have installed the WMA codec already, I don't really understand, why the error message is "Error: Unable to load decoder for file type '.wma', codec not installed?" for the wma file. Can you see in the Control Center that the WMA codec is installed? Is the 32bit or 64bit Version of the WMA codec installed? Are you running the 32bit or 64bit version of dBpa?
                  If the encoder has been faulty, that could be a problem. But that does not explain the error message above.
                  • Trickster
                    • Jun 2018
                    Re: Codec Issues
                    I'm currently running the 64 bit version of the software on windows 10. I saw the list of codecs you posted on here to a previous reply I clicked on them and downloaded not long back. I wasn't aware of that list until now. I clicked on the relevant codecs matching the specifications of the software I'm running hopefully that should ease the issues I've been having.
                    I'll have a go at converting the tracks I've been having trouble converting if the same still happens even though downloading the relevant codecs I'm going to have to rip it again and do it that way.
