Problem with asset UPnP with and Cambridge Audio NP30
Hi
I have following configuration.
Windows7 64bit and Asset UPnP4.1 installed.
As renderer I use an NP30 from Cambridge Audio.
When I'm playing back a flac file (CD Rip) I get dropouts after about 40s.
Playing a mp3 or ALAC file works without problems.
As I find out, the 40s is about the buffer size of the NP30.
For testing I installed another UPnP Server (Minim) on the same computer and there is no problem with Flac playback.
Is there a setup problem in Asset or what can I try?
Regards
Beat
Re: Problem with asset UPnP with and Cambridge Audio NP30
Try setting asset to serve FLAC 'as wave'
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
