Metadata lost when converting from ALAC to FLAC (not all files)
  • stephenrjr
    • Feb 2017
    • 22
    Started to Batch Convert my entire library from lossless ALAC to FLAC and started noticing that some of the files lost their metadata in the process. Isolated a good example (can produce many) of a working file and a broken file both from the same ripped CD. The CD was originally ripped using 'dBpoweramp Release 14.4' using encoder 'Apple Open Source ALAC v1.0'; I'm currently using R16.4 to perform the conversions.
    Is this a known issue?
    I'm happy to provide before and after files for analysis.
    -Stephen
    • 43902
    Re: Metadata lost when converting from ALAC to FLAC (not all files)
    Can anything else see the metadata in the ALAC files?
    • stephenrjr
      • Feb 2017
      • 22
      Windows is able to display in Explorer when the folder is set to view type Music (Name, *, Title, Contributing Artists, Album, etc)
      And using ID-Tag Editor, all of the metadata is shown.
      Neither method works on the converted FLAC file.
        • 1745
        Could you please post a screenshot of the meta data of the converted flac? I have an idea...
        • stephenrjr
          • Feb 2017
          • 22
          I must apologize - my original problem description is actually incorrect. For the files that are missing metadata, the audio conversion is actually failing; the output file is merely a ~4-5K partial.
          Digging deeper, a check of the Event Log reveals these errors:
          Faulting application name: CoreConverter.exe, version: 16.4.0.2, time stamp: 0x5a456e59
          Faulting module name: FLAC.DLL, version: 16.3.0.0, time stamp: 0x59fb3943
          Exception code: 0xc000001d
          Fault offset: 0x0000000000035523
          Faulting process id: 0x6594
          Faulting application start time: 0x01d3fb3d9fab45bd
          Faulting application path: C:\Program Files\dBpoweramp\CoreConverter.exe
          Faulting module path: C:\Program Files\dBpoweramp\encoder\FLAC.DLL
          Report Id: f0c6317e-e5ce-4043-bdce-57f80634cef3
          Faulting package full name:
          Faulting package-relative application ID:
          Windows cannot access the file for one of the following reasons: there is a problem with the network connection, the disk that the file is stored on, or the storage drivers installed on this computer; or the disk is missing. Windows closed the program dBpoweramp CoreConverter because of this error.
          Program: dBpoweramp CoreConverter
          File:
          The error value is listed in the Additional Data section.
          User Action
          1. Open the file again. This situation might be a temporary problem that corrects itself when the program runs again.
          2. If the file still cannot be accessed and
          - It is on the network, your network administrator should verify that there is not a problem with the network and that the server can be contacted.
          - It is on a removable disk, for example, a floppy disk or CD-ROM, verify that the disk is fully inserted into the computer.
          3. Check and repair the file system by running CHKDSK. To run CHKDSK, click Start, click Run, type CMD, and then click OK. At the command prompt, type CHKDSK /F, and then press ENTER.
          4. If the problem persists, restore the file from a backup copy.
          5. Determine whether other files on the same disk can be opened. If not, the disk might be damaged. If it is a hard disk, contact your administrator or computer hardware vendor for further assistance.
          Additional Data
          Error value: 00000000
          Disk type: 0
          Enabling Music Converter debug output, this is produced:
          Splitting Command Line:"C:\Program Files\dBpoweramp\CoreConverter.exe" -dbcmd="C:\Users\steph\AppData\Local\Temp\dBT66BB.t mp"
          ->-> [dBCoreConverter::ReaddBCommandFile]
          <-<- [dBCoreConverter::ReaddBCommandFile]
          Decodes [clDecoder_M4A::Get]
          BatchID [clDecoder_M4A::Set]
          ->-> [cldBCodecHandler::LoadEncoder]
          Loading Encoder 'C:\Program Files\dBpoweramp\encoder\FLAC.DLL'
          <-<- [cldBCodecHandler::LoadEncoder]
          BatchID [clEncoder::Set]
          ->-> [dBCoreConverter::StripCoreConverterCmds]
          <-<- [dBCoreConverter::StripCoreConverterCmds]
          SendRawUnCompressed [clEncoder::Get]
          IsLive [clDSP_FolderJpgPreserve::Get]
          SendOverReplayGainTags [clDSP_FolderJpgPreserve::Get]
          BatchID [clDSP_FolderJpgPreserve::Set]
          Communicate [clDecoder_M4A::Get]
          Communicate [clEncoder::Get]
          NeedHQAudio [clEncoder::Get]
          ->-> [clDecoder_M4A::Open]
          ->-> [clDecoder_M4A::Close]
          <-<- [clDecoder_M4A::Close]
          Opening file 'M:\Music Masters\Secure\ALAC\Ac-Dc\Back In Black\03 Ac-Dc - What Do You Do For Money Honey.m4aOpened
          Opening tag reader / writer: Opened
          ->-> [clMP4Handler::ScanFile]
          Got Chunk 'ftyp' Length: 32 ChunkPosition: 0
          Got Chunk 'moov' Length: 15074 ChunkPosition: 32
          Got Chunk 'mdat' Length: 26603093 ChunkPosition: 15106
          <-<- [clMP4Handler::ScanFile]
          Got Chunk 'mvhd' Length: 108 ChunkPosition: 40
          Got Chunk 'trak' Length: 11584 ChunkPosition: 148
          Got Chunk 'udta' Length: 3374 ChunkPosition: 11732
          ->-> [cliTunesTag::Initialize2]
          Looking for meta block...
          ->-> [cliMemoryAtomParse::Initialize]
          <-<- [cliMemoryAtomParse::Initialize]
          Found meta, looking for ilst block...
          Found ilst.
          <-<- [`anonymous-namespace'::clTagInitState::ReadUdata]
          ->-> [clDecoder_M4A::ReadIDTags]
          Contains 19 ID Tags
          Title: What Do You Do For Money Honey
          Year: 1980
          Composer: Brian Johnson/Angus Young/Malcolm Young
          Disc: 1/1
          Label: Atco
          UPC: 075679241825
          Style: Hard Rock/Heavy Metal/Arena Rock/Album Rock/Aussie Rock
          Album: Back In Black
          Genre: Pop\Rock
          Artist: Ac/Dc
          Album Artist: Ac/Dc
          MetaProvider: Mixed Providers
          Rating: 10
          Track: 3/10
          AccurateRipResult: Accuraterip: Accurate (Confidence 8) [efed909c]
          AccurateRipDiscID: 010-00105f5b-00810c86-7109d50a-3
          Source: Cd (Lossless) >> Perfect (Lossless) [m4a] >> Perfect (Lossless) [m4a]
          Encoded by: Dbpoweramp Release 16.4
          Encoder: Apple Open Source Alac V1.0
          <-<- [clDecoder_M4A::ReadIDTags]
          Searching for AAC Track:
          not found, trying ALAC:
          Got Chunk 'tkhd' Length: 92 ChunkPosition: 156
          Got Chunk 'mdia' Length: 11484 ChunkPosition: 248
          Got Chunk 'mdhd' Length: 32 ChunkPosition: 256
          Got Chunk 'hdlr' Length: 36 ChunkPosition: 288
          Got Chunk 'minf' Length: 11408 ChunkPosition: 324
          Got Chunk 'smhd' Length: 16 ChunkPosition: 332
          Got Chunk 'dinf' Length: 36 ChunkPosition: 348
          Got Chunk 'stbl' Length: 11348 ChunkPosition: 384
          Got Chunk 'stsd' Length: 88 ChunkPosition: 392
          Got Chunk 'stts' Length: 32 ChunkPosition: 480
          Got Chunk 'stsc' Length: 40 ChunkPosition: 512
          Got Chunk 'stsz' Length: 9304 ChunkPosition: 552
          Got Chunk 'stco' Length: 1876 ChunkPosition: 9856
          Created
          ->-> [clDecoder_M4A::FillAudioProps]
          Encoder: Apple Lossless (ALAC)
          Sample Count: 9,505,020
          ID Tag: Apple iTunes
          Contains: ID Tag [Apple iTunes]
          <-<- [clDecoder_M4A::FillAudioProps]
          ->-> [clDecoder_M4A::FillAudioInfo]
          Uncompressed WFX (sent to db): Format Tag: 1 Channels: 2 Bits per Sample: 16 Samples Per Second: 44100 Bytes Per Second: 176400 Block Align: 4 CB Size: 0
          Audio Length: 215533 mili-seconds 26618199 bytes 1411 kbps
          <-<- [clDecoder_M4A::FillAudioInfo]
          Creating Decode Buffer: Created
          <-<- [clDecoder_M4A::Open]
          SendOverReplayGainTags [clEncoder::Get]
          ->-> [clDSP_FolderJpgPreserve::BeginConversion]
          <-<- [clDSP_FolderJpgPreserve::BeginConversion]
          ->-> [clEncoder::BeginConversion]
          Converting to 'U:\Test Conversions\Secure\ALAC\Ac-Dc\Back In Black\03 Ac-Dc - What Do You Do For Money Honey.flac' encoder settings ' -compression-level-5 -verify'
          FLAC Compression Level: 5
          <-<- [clEncoder::BeginConversion]
          Encoding To: FLAC
          Encoder Cmd Line: -compression-level-5 -verify
          DSP Effects:
          Folder.jpg Preserve: -ext=""
            • 43902
            Try R16.5 which is in the testing section of this forum.
            • stephenrjr
              • Feb 2017
              • 22
              R16.5 beta worked just fine.
              Fixed by updated FLAC 1.3.3 beta ?
                • 43902
                Yes, we will release R16.5 in a around 8 weeks.
                • rsk5
                  • Mar 2019
                  Has this been resolved? I will convert FLAC (and perhaps WAV) files created from Audacity to ALAC. Does dBpoweramp retain metadata when doing this? I would settle for all the basic, standard Audacity fields (album name, artist name, track [song] title, album title, track number, year, genre, and comments), but if anyone has tried custom fields in Audacity, corresponding to other song info in iTunes (like composer or disc number), does that work? Thank you!
                    • 43902
                    It does preserve the tags.
