24-bit conversion to MP3 320kbps
  • danahirschberg
    • May 2016
    I have some albums in 24-bit 96k and 192k. Converting to MP3 16-bit 44.1k can cause dither and other sound quality issues. Is there a suggested workaround to getting the best quality MP3 files exported to sound the best they can?
    • 5744
    Re: 24-bit conversion to MP3 320kbps
    Convert with the Resample DSP set to 44,1kHz, the Bit Depth DSP set to "Fixed 16bit" and Apply Dither "Triangular (TPDF)
      • 43923
      No need to set 16 bit for mp3, as it will accept 24 bit (note mp3 is bit depth independent).
        • 5744
        oops. Forgot that this wasn't FLAC 24/96 to FLAC 16/44.1.
