Word / Character Replacement on "Edit ID-Tags"
  • mwthreex
    • Feb 2018
    • 19
    hi there, i'd like to replace some characters to another like this section :
    But it seems only available when we convert something...
    Is it possible to use above feature at "Edit ID-Tags"? :
    I did'nt find anything about it, It's very hard to manually edit each tracks.
    • 43898
    Re: Word / Character Replacement on "Edit ID-Tags"
    Install the utility codec 'ID Tag Update', convert the file(s) to this utility encoder and set the replacement in the ID Tag Update settings page.
    • mwthreex
      • Feb 2018
      • 19
      Thanks but I don't wanna convert a file, I need a Replacement profile or something like this to change all characters without converting.
        • 1745
        Even so you choose the codec "ID Tag Update" to convert your files, the files will be updated only. Don't worry!
        • mwthreex
          • Feb 2018
          • 19
          Thanks Spoon & Dat Ei <3
