Results 1 to 3 of 3
Thread: Problem upgrading to Asset 6.1 on WHS v1
  1. #1
    Join Date
    Sep 2010
    Am currently running Asset 5.2 and trying to update to 6.1 on WHS v1 machine (Zoneripper)
    Following the install instructions, I have downloaded the AssetUPnP-WHS.msi file and copied it to the Software\Add-Ins Folder on the Zoneripper. When accessing Add-Ins from the Windows Home Server Console it appears correctly in the list of Available Add-Ins.
    When clicking on 'Install' I get the following error message: "Windows cannot open this program because it has been prevented by a software restriction policy. For more information, open Event Viewer or contact your system administrator."
    Clicking "OK" brings up a further "Installation Failed" window with the message, "The selected add-in failed to install. The error code was 1603. Please contact the add-in author for assistance."
    (On looking in Event Viewer there did not appear to be any additional relevant information.)
    Incidentally, within the Asset UPnP window within the Windows Home Server Console I do have a button which says "Upgrade to 6.1" but have not not clicked on it but followed the supplied installation instructions instead.
    Please advise.
    Steve
  2. #2
    Join Date
    Apr 2002
    Re: Problem upgrading to Asset 6.1 on WHS v1
    Uninstall the old asset. Then remote desktop connect into the Zone ripper, create a folder:
    c:\install
    and save the install to that folder, then run direct from that folder (double click) using remote desktop connection.
  3. #3
    Join Date
    Sep 2010
    Thanks. All done and all looking good.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
