Activation does not work
  • RoundRobin
    • Jan 2018
    Dears,
    I had installed the trial version of Asset then purchased the registered version. After installing (in fact, twice uninstalling/reinstalling), I still get: "Trial (xx days remaining)" in the config window. What to do ?
    • 43926
    Re: Activation does not work
    Which version? Windows?
    Just to check you have downloaded the registered version and are running that (the installer will have 'Premium' in the name).
    Try uninstall, full restart of Windows and reinstall Asset.
    • RoundRobin
      • Jan 2018
      Dear Spoon
      yes it is Windows. The file name is "AssetUPnP-Windows-reg.exe" (the file I downloaded after payment) and the word "Premium" does not show up (it says it is version 6.1).
      Any help will be welcome !
        • 43926
        This is the correct install, did you try the restart of Windows after uninstall?
