Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: Help needed to connect FLAC library to Apple Lossless
  1. #16
    Join Date
    Nov 2007
    Location
    Florida, USA
    Re: Help needed to connect FLAC library to Apple Lossless
    try this for dynamic naming to get rid of the first 3 folders you don't want.
    [TRIMFIRSTFOLDER][TRIMFIRSTFOLDER][TRIMFIRSTFOLDER][TRIMFIRSTFOLDER][TRIMFIRSTFOLDER][origpath][][]\[origfilename]
  2. #17
    Thanks garym I will try this. However I have managed to resolve my initial apple music issues via the earlier smartlist suggestion.
  3. #18
    Join Date
    Nov 2007
    Location
    Florida, USA
    Quote Originally Posted by paul44birch View Post
    Plus, you could simply highlight and select all the artists files below "flac" folder in your example, then paste these directly into the APPLE directory you created. Then delete the "paul w", music, flac copies directories (which at this point will be empty). Then all your artist and album files in ALAC are underneath the upper level APPLE directory.
  4. #19
    Ah, of course. Simple but I didn't think of that!
    Cheers garym
Posting Permissions
  • You may not post replies
  • You may not edit your posts
