In the 'Audio Library Select Folder' type into the white text box:
Z:\
then press enter, what happens?
Z:\
It is Windows which is giving that error, it means the network share is not available to which ever account Asset Configuration is running in, normally it is the same account if you have administrator access rights, how many user accounts do you have? Try logging onto each of them and mapping the network drive on each.
Many thanks, Spoon. I am using my own account which has administrator rights.
The only other account is my wife's which she uses on rare occasions. I have now changed her user status to administrator, logged in as her, mapped the drive Z: and found she has exactly the same issue as me.
Then went back to my account and find that nothing has changed.
Yes, mville, that is correct.
Can you navigate within file explorer down to your flac files?
Do you use any other Illustrate products?
Yes, it appears I am: -
Bingo! That worked a treat! Just scanned my entire library in just a few minutes.
Many thanks for your help, mville. Also thanks to Spoon and Dat Ei. It's really appreciated, guys.
Not sure what I did different this time but the main thing is it worked. Strange thing is I still can't see Z: mapping. All that matters is it works.
Now, I can dispense with Linn Kazoo Server and set up everything exactly the way I want it in Asset. Thanks again.
