Products            Purchase            Codec Central            Forum & Support            Professional            About
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
Thread: Ripper Drive Configuration Issues
  1. #16
    Join Date
    Nov 2017
    Re: Ripper Drive Configuration Issues
    No. The other parameters you refer to ARE drive specific.
    Exactly... But the program treats them like globals (same for both drives) hence the issue. If you want to separate them you need to setup a profile for each drive.
  2. #17
    Join Date
    Dec 2008
    Location
    London, UK
    Quote Originally Posted by Steve Sr. View Post
    Which version of dBpoweramp Music Converter have you installed?
    I have dBpoweramp R16.3, 64-bit installed on a Windows 10 Pro PC and I can configure different drive settings, without the need to set-up separate profiles.
    ... just to clarify, the drive settings being:
    Drive Read Cache
    Clear Read Cache with FUA
    C2 Error Pointers for Error Detection
    8KB Transfers (C2 Pointers over USB/Firewire)
  3. #18
    Join Date
    Nov 2017
    [QUOTE=mville;179748]Which version of dBpoweramp Music Converter have you installed?
    I have the same version running on Win 7 Pro x64.
    Drive Read Cache
    Go back and reread post *8. These are NOT the parameters that I was referring to.
  4. #19
    Join Date
    Dec 2008
    Location
    London, UK
    So we are now going full circle in this thread and the question still remains!
    Why do users need different Ultra Secure Passes and Maximum Re-Reads for different drives?
    I'm not sure and you haven't given a convincing reason why, but if you must have different Ultra Secure Passes and Maximum Re-Reads, you are able to setup different profiles. No big deal.
  5. #20
    Join Date
    Nov 2017
    Go look at the CD Ripper configuration instructions paying close attention to the differences between C2 and non-C2 drives.
  6. #21
    Join Date
    Dec 2008
    Location
    London, UK
    Yes, I understand that, but I am yet to be convinced (after ripping CDs for many, many years) that having these different software settings is important, especially when you consider how often drives claim to support C2 but don't implement the support (as Spoon has already mentioned) and that we have the AccurareRip feature. FYI, I have a drive that reports to support C2, but it does not.
    However having said that, I have also said if you must have different Ultra Secure Passes and Maximum Re-Reads, you are able to setup different profiles. No big deal.
  7. #22
    Join Date
    Nov 2017
    I am just trying to follow the Ripper configuration directions which cannot be done without using profiles if you have both a C2 and a non-C2 drive.
  8. #23
    Join Date
    Dec 2008
    Location
    London, UK
    Personally, I would leave the Ultra Secure Passes and Maximum Re-Reads settings the same and I wouldn't be too concerned at the moment. In my experience, it won't be an issue as CDs that are badly scratched or have manufacturing errors won't rip successfully in any drive, regardless of the settings. If and when you come across such a CD, then I would experiment with the ultra secure settings to see if you can rip the damaged CD.
    What is important is that when you rip, your CD Rip Status reports as Accurate, so ultra secure mode is irrelevant. The good news is you have 2 drives. If a CD does not rip in one, it may rip in the other, as an AccurateRip.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Copyright 2018 Illustrate. All Rights Reserved.
