Re: how to apply replay gain while converting mp3 speech files to opus
How to obtain same volume while listening to the converted opus file in android phone with headphones.
I want to get same volume throughout the file I mean I don't want ups and downs while listening to opus file. Is there any DSP to achieve this.
Suppose while listening to original mp3 source file at point A I got 90 % of maximum volume of my headphones and at point B I got 50% percent of maximum volume of my headphones and at point C I got 95 % of maximum volume. I want to convert to convert this mp3 file to opus file and if I listen this opus file in android phone with headphones I must get say 80 % of maximum volume of my headphones I mean there must be no ups and downs say 90 % at point A, 50 % of maximum volume at point B, 95 % of maximum volume at point C.
Choose the 'Adaptive' option on the Volume Normalize DSP Effect.
Under volume normalize I found two options starting with adaptive they're
Adaptive ( EBU R128 )
Adaptive ( Peak to Peak )
Under the above both options I found the following entries
Window Length ____ ms
Desired Volume ____db
Maximum Amplification x ___
Info: Non-Live Dsp Effect
I can't understand the above settings. I want to maintain same volume say 85 db through out the file for all files and so please suggest how to do so I mean which options to select and their values.
Leave everything on default settings and choose 'Adaptive EBU R128'
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
