Products            Purchase            Codec Central            Forum & Support            Professional            About
Page 9 of 19 FirstFirst ... 7891011 ... LastLast
Results 121 to 135 of 276
Thread: Tags, Tags, and more Tags ...
  1. #121
    Join Date
    Jul 2017
    Location
    Wirral, UK
    Question Re: Tags, Tags, and more Tags ...
    Hi.
    (There area couple of typos in my above post I just noticed!).
    I am thinking that the two possible solutions here would be to either completely lose the word 'The' and catalogue ARTIST SORT as: 'Williams, Tony, Lifetime'; or else include the word 'The' and place it at the end (ie. ARTIST SORT = 'Tony Williams Lifetime, The')?
    Many thanks,
    Paul
  2. #122
    Join Date
    Sep 2016
    Location
    Michigan, USA
    Quote Originally Posted by monsterjazzlick View Post
    I have another ARTIST (Band) I am tagging containing similar data: 'The Tony Williams Lifetime'. [-snip-]
    Why TW used the word 'The' seems a bit pointless and less attractive to me than simply calling the outfit 'Tony Williams Lifetime'. Maybe it was because it was because his surname would need to be Williams's which caused them to prefer the word 'The'?
    I think it was the hip thing back then, just as with The Jeff Lorber Fusion.
    In 'dBpa' it appears, by default, as: 'Williams, Tony, Lifetime, The'; but I don't think you would agree with this format.
    I, personally, would use Tony Williams Lifetime if I had CDs under his name only (which for me would list as Tony Williams), or The Tony Williams Lifetime if I didn't.
    I don't so much disagree with the dBpa format, which will do what you need when sorting by surname. I just find it difficult to decipher at a glance.
  3. #123
    Join Date
    Jul 2017
    Location
    Wirral, UK
    Quote Originally Posted by Jailhouse View Post
    Hi JH,
    Thanks a lot.
    I have settled for (dropping the 'The'): 'Tony Williams Lifetime' / 'Williams, Tony, Lifetime'. I think that should work OK.
    The 'dBpa. default is OK when the name/artist is 'John Smith'. But when you have (say) 'Duke Ellington And His Orchestra', then things can, understandably, get a little muddled. But of course nobody would ever expect the s/w to be 100% correct every time as different users prefer different listings!
    This ripping malarkey is a big job! It's never ending ...
    Many thanks,
    Paul
  4. #124
    Join Date
    Sep 2016
    Location
    Michigan, USA
    If you want to sort by surname, it has to come first. A Williams, Tony, Lifetime tag would work fine; adding The at the end is superfluous, as it doesn't change the sort order.
    If I were to start using sort tags, I would seriously consider using <last name, first name> followed by a number. Jeff Lorber would be sort-tagged as Lorber, Jeff 01; The Jeff Lorber Fusion as Lorber, Jeff 02; and Jeff Lorber Fusion as Lorber, Jeff 03. It would put the first several 'Fusion' releases (beginning with 'The') before the later ones and save me a lot of head-scratching.
    I could also use this method to sort two [or more] albums released in the same year with titles don't sort the same alphabetically as they do chronologically; that's the drawback to not using full release dates.
  5. #125
    Join Date
    Sep 2016
    Location
    Michigan, USA
    The 'dBpa' default is OK when the name/artist is 'John Smith'. But when you have (say) 'Duke Ellington And His Orchestra', then things can, understandably, get a little muddled.
    Ellington, Duke, And His Orchestra
    It's a smaller job for me; I don't require so much information.
  6. #126
    Join Date
    Jul 2017
    Location
    Wirral, UK
    Cheers JH,
    Well, I think I must be close to half way through now. I have ripped over 70GB (which probably seems a very small amount to you!).
    Paul
  7. #127
    Join Date
    Jul 2017
    Location
    Wirral, UK
    Hi there,
    I have an Xmas Jazz CD which contains zero information regarding anything (other than the tunes!):
    In which case, would you just write the track-titles and composer-names and leave everything else blank? I mean, I don't really think there is much else you can do here?
    (Discogs site has included in the Genre tag: Country, Folk, World Music! lol.)
    Cheers,
    Paul
  8. #128
    Join Date
    Sep 2016
    Location
    Michigan, USA
    You're probably right. Put in what information you have, and add more when (if) you can find any.
  9. #129
    Join Date
    Apr 2015
    Location
    England
    Hi there,
    Cheers,
    Paul
    You could use Genre, Christmas.
    Or perhaps, Jazz.
    I'll admit to having Genre, Christmas. Very handy alongside the Genre, Party, I mentioned to you!
  10. #130
    Join Date
    Apr 2015
    Location
    England
    Hi Paul,
    Meant to mention, if you enter anything in the Genre box, you'll end up with Unknown Genre, so easier to enter something, at the time of rip.
  11. #131
    Join Date
    Jul 2017
    Location
    Wirral, UK
    Quote Originally Posted by Oggy View Post
    Or perhaps, Jazz.
    Hi Oggy,
    Because I only have this solitary one Xmas CD, I am tempted to just whack in under Jazz Genre and Xmas Style.
    The Genre folders I have to date are: Jazz, Prog. Rock, and Film Soundtrack.
    Paul
  12. #132
    Join Date
    Jul 2017
    Location
    Wirral, UK
    Hi JH,
    The reason I ask is because where I have not been able to source the required data in the past, I have written in 'Unknown'. For instance:
    Producer = Unknown
    Composer = Unknown
    But now I am thinking I might be better not stating this. I think it was Gary who said he does not type in 'Unknown' because 'Unknown' tells him nothing! In which case, if I leave a field (such as 'Producer') BLANK, then does this tag just get deleted during the ripping process (because there is no metadata in it)?
    Many thanks,
    Paul
  13. #133
    Join Date
    Dec 2008
    Location
    London, UK
    I have a composer list in foobar2000. Any tracks without the composer tag are omitted from the list, but tracks with composer = unknown, appear under unknown, which I find quite useful.
    ... also, historically in some software, I found searching for tracks without certain tags problematic. That is, tracks were not returned if the tag was missing. As composer for me is quite important, I ended up with composer = unknown (and composersort = unknown).
  14. #134
    Join Date
    Jul 2017
    Location
    Wirral, UK
    Nice one mville.
    I was dreading having to make amendments to circa 80GB!
    I do not use COMPOSERSORT.
    I will make a rip and post a screenshot shortly ...
    Paul
  15. #135
    Join Date
    Dec 2008
    Location
    London, UK
    Why not?
    In addition to my comments earlier, during my tagging exploits, I discovered that for some tracks the composer is literally unknown. I am now able to distinguish between this and tracks where I have not added the composer (as composer does not exist).
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Copyright 2018 Illustrate. All Rights Reserved.
