Products            Purchase            Codec Central            Forum & Support            Professional            About
Results 1 to 10 of 10
Thread: Initial problems using CD Ripper for the first time
  1. #1
    Hi, when I try to ripp a CD I get the follwing message from the CoreConverter saying that the application could not be startet correctly (0x0000142): cc142.PNG
    Pressing ok ripping continues and I get a positiv successs message saying that all files has been ripped: rip1.PNG
    Looking at the file system on my server a new folder has been created correctly but with just one file stored in it: the jpeg of the cover: rip2.PNG
    What runs wrong? What can I do?
    Thanks for your help!
  2. #2
    Join Date
    Dec 2008
    Location
    London, UK
    Re: Initial problems using CD Ripper for the first time
    Are you able to translate the message in first picture to English?
    Are you able to rip OK, to a local hard drive, rather than a network location?
  3. #3
    the translation is:
    CoreConverter.exe - Application error
    The Application could not be startet correctly (0x0000142). Press OK to close the application
    I tied both ripping to my hard drive as well as to my network server - same result.
  4. #4
    Join Date
    Dec 2008
    Location
    London, UK
    Try turning off your anti-virus/security software and try again.
  5. #5
    Same result - I de-activated my anti virus scan software (McAfee) and tried ripping against my local hard disc as well as against my server: I got the same error message and when CD Ripper has finalized I just see a new folder with just the cover art - no FLAC files.
    What I haven't done is to de-activate my fire wall - I hope this is not part of your suggestion.
  6. #6
    Join Date
    Dec 2008
    Location
    London, UK
    The CoreConverter.exe error needs resolving.
    What OS/platform and dBpoweramp Music Converter version are you running?
  7. #7
    I am running Windows 10 Home Version 10.0.14393 Build 14393
    and dBpoweramp Release 16.2 [64-bit]
  8. #8
    Join Date
    Dec 2008
    Location
    London, UK
    Try re-installing R16.2 (or 16.3 beta 4) without your anti-virus/security software running and try again.
  9. #9
    I de-installed dBpoweramp and installed it again while the anti virus software was de-activated as well as my fire wall - same result: error message, no FLAC files
    I used the same download as I used for my first installation - if you think I should use a newer version how can I get the download for it?
  10. #10
    Join Date
    Dec 2008
    Location
    London, UK
    You could try the latest R16.3 beta 4: dBpoweramp R16.3 Beta [Windows]
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Copyright 2018 Illustrate. All Rights Reserved.
