A quick update...
It turned out that the foo_dsp_effect package I had installed (an older version) included a de-emphasiser as well, and it seems that was the cause of the issue. I uninstalled it and all is well. I remain confused that even when the old foo_dsp_effect package was installed, I had not activated the de-emphasis dsp... I can only presume it acts on files with a PE tag even when not activated.
I have since installed the up to date foo_dsp_effect package and it would seem the de-emphasis dsp is no longer included in it.
It has left with with some other questions and ponderings which I have raised over in the HA forum:
https://hydrogenaud.io/index.php/topic,114610.0.html
If you (or anyone) have anything to say about those, then please chip in!
Either way, thanks for all the help you've given me
Glad you got it sorted re. the foo_dsp_effect. I thought it was something like this, hence my earlier point about applying other non-deemphasis EQ/DSP.
Regarding foo_dsp_deemph (from the foobar2000 site):
To CD de-emphasize a track automatically, add a tag named PRE_EMPHASIS or PRE-EMPHASIS with a value of "1", or "on" or "yes". Other tracks are unaffected.
